SOURCE: where to buy wire feed rollers for chicago
I belive Home Depot and Sears carry that brand.And possiably Harbor Freight.
SOURCE: I bought a Chicago Electric
go to this link
http://www.harborfreight.com/120-amp-230-volt-mig-and-flux-welder-97503.html
click on product manual for download of the manual the link below may work as well.
http://manuals.harborfreight.com/manuals/97000-97999/97503.pdf
Testimonial: "Thank you it wasa big help."
SOURCE: can't fine a operate-parts manual for a chicago arc 180 welder
I would go ahead and contact someone with <a href="http://www.suburbanweldingandsteel.com">chicago welding</a> they really know will be great.
SOURCE: can not find parts for Chicago electric 200 amp welder
You may not need to replace the board if the wire feed failed- most often it is an SCR or pair that has failed. Usually what is used is a 6 amp 600 volt SCR- you can go higher current and voltage for reliability. just make sure the heat sink is adequate or larger and heat transfer compound is used. Digi Key carries the "Teccor" SCR's other brands of the same or higher ratings will work.
