The indicator LED flashes red & green. I've tried doing the software update but nothing happens. Putting the old board back in and the TV works.
SOURCE: Green Screen
hey guys i just but my ps3 console , am trying to upgrade te firmware he just go blank . i can;t return it back to the store .wat can i do ? to make it works , pls reply me to my email [email protected]
SOURCE: TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
SOURCE: tvstopped working, green power light comes on, red light flashing
Most likely it has a power supply module problem. Have it looked at by a qualified service company.
SOURCE: Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
