20 Most Recent Sony BRAVIA KDL-V32XBR2 32 in. HDTV LCD Questions & Answers
Sony KDL-V32XBR2 - no picture, no sound...I'm pretty sure the hdmi input port is damaged...is it worth it to repair/replace? and can I do it myself?
Yes ,you should replace the main board ,because you can'nt repair HDMI interface. Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen
8/2/2018 8:30:14 AM • Sony BRAVIA ... • Answered on Aug 02, 2018
I can not get my
Your HDMI lead is too long or not high enough quality. Don't use a cheap one. Trust me....
9/7/2017 11:46:40 PM • Sony BRAVIA ... • Answered on Sep 07, 2017
Standby blinks 4 times
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Note: This particular model also has one additional step to perform besides the capacitors to fix it properly. There is some loose solder on a few parts that you will need to redo. So if you get a kit from Tv Repair Kits send them a remider that you have the HP-T4254 model so that you need the info on the other step.
5/1/2011 10:24:11 PM • Sony BRAVIA ... • Answered on May 01, 2011
0answers
Sony kdl-v32xbr2 - blank screen with volume.
Pull the power plug from the wall, and replug.
5/5/2010 2:45:03 PM • Sony BRAVIA ... • Answered on May 05, 2010
My Sony BRAVIA KDL-V32XBR2 32
please try differect sources e.g. dvd, cable TV box, aerial. Also check that your connectors are properly plugged in. If none of those work, bring your tv to the nearest service center.
cheers!
7/11/2009 12:49:08 PM • Sony BRAVIA ... • Answered on Jul 11, 2009
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it. I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
9/30/2022 3:10:56 AM • Sony BRAVIA... • Answered on Sep 30, 2022
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
8/25/2022 5:14:39 AM • Sony BRAVIA... • Answered on Aug 25, 2022
Sony 65 inch TV, KD-65X750F not getting any power from stand-by pin on power board?
Do you get voltage with the main board unhooked?
3/27/2022 11:56:41 PM • Sony BRAVIA... • Answered on Mar 27, 2022
Sony 49 XBR 900 E power will not come on unless the plug is taken out from the set and reconnected. Can you tell me which board should be replaced?
what plug not told./PC is dead?no it is not a PC it is a television posted to wrong forumnow corrected.is TV set to sleep mode, RTM read the manual on TVare the clicker remote batteries fresh>?
3/24/2022 2:55:41 PM • Sony BRAVIA... • Answered on Mar 24, 2022
How can I watch Netflix on a tv Sony wega that isn’t hooked to the internet. It’s wirelessly connected to Vizio ( smart tv Netflix built in) but I want to be able to watch in a different room
netflix is a 100% internet web site , streaming site. thus the net in flix. what did you mean by hooked?\ do you have internet at home at all? do other things in home work to the internet, like PC or cell phones. what I can not under stand is (different room) this phase implies some rooms do work (netflex) and wifi gets weak if my move any TV farther from the home router and will fail past 25 feet or more. wifi is super weak through walls for sure brick, or 2 walls. if home is small one wifi access point is all you need if huge home more. distance matter, TV to router. no TV model # told. (tells me wifi spec) if you said my TV works in room 1 but not room 2, wifi;. it be super more easy to answer.. is this true? if true , get a tech to upgrade your wifi. or go wired, Ethernet.(a better home upgrade)
3/24/2022 2:24:22 PM • Sony BRAVIA... • Answered on Mar 24, 2022
I have a 85 inch Sony Bravia TV. I have sound but no picture
Hello !! what do you mean by you replaced the video card ? mainboard or t-con ? , we need more information
2/1/2022 12:21:49 AM • Sony BRAVIA... • Answered on Feb 01, 2022
Sony bravia 40" kdl-40v3000 stand screws
They are usually M6 or M8. You can get them from Home Depot or Sainsbury Homebase.. These are listed as the correct ones. https://www.ebay.com/itm/4-STAND-FIXING-SCREWS-FOR-SONY-KDL-40U3000-KDL-40V3000-KDL-40D3000-KDL40W3000-TV-/322578615461 and here as well, the same type https://www.ebay.co.uk/itm/272144950454?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338722076&customid=&toolid=10050 ..
11/30/2021 5:53:30 PM • Sony BRAVIA... • Answered on Nov 30, 2021
I have Sony Bravia 32r402a with demo loop running. Also the power light blinks many times thereafter input select tv/hdmi/video keeps flashing. Any action for remedy?
Sounds like a bad main board, or more specific the EEPROM is bad on the main
11/13/2021 8:41:51 PM • Sony BRAVIA... • Answered on Nov 13, 2021
Why does my Sony Bravia TV keep going to standby?
Check power supply caps
10/18/2021 12:22:02 PM • Sony BRAVIA... • Answered on Oct 18, 2021
Sony Bravia KDL-50R550A keeps turning on and off after 15 seconds? Changed batteries & unplugged 60 seconds. Should I reset?
You can try but I don't think that will help, sounds like power supply issues, open the back and look for bulged caps
10/11/2021 12:09:29 AM • Sony BRAVIA... • Answered on Oct 11, 2021
No sound some channels
HI IN THIS CASE YOU LED TV CHANG AUDIO FORMATE PLEASE GO TO TUNING SECTION THEN IN FINE TUNING AND THERE IS SOUND OPTIOND LIKE BG DK I AND M SELECT ONE ACCORDING TO YOUR COUNTRY THANKS M NASIR
10/3/2021 4:54:49 PM • Sony BRAVIA... • Answered on Oct 03, 2021
Hi, I've Sony Brevia LCD tv model # kdl 32bx300. Its displaying green discolored pictures. Is it T Con board problem or main board issue?
Hi dear its main board problem and some time LVDS FFC cable problem . thanks M Nasir
10/1/2021 6:19:26 PM • Sony BRAVIA... • Answered on Oct 01, 2021
I have a sony bravia 55" TV, the model # is kdl 65w850c with a part that came loose. According to the Service Manual I downloaded, it's called a BT antenna.
THe antenna came of. Did you use it and is it giving troubles now? If not, then don't mind and leave it.
7/17/2021 3:24:06 PM • Sony BRAVIA... • Answered on Jul 17, 2021
Sony BRAVIA  KDL-V32XBR2 32 in. HDTV LCD Logo
10 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
standby blinks 4 times
  • Televison & Video
