SOURCE: right side axle shaft support bearing removal
Change the whole axle. You will waste TONS of time trying to change that bearing, and it is virtually impossible for a guy to do it without a real good machine shop. Trust me. Change the whole axle.
SOURCE: right front bearings need lube
Your vehicle has sealed front wheel bearings,they cannot be greased,the only solutuion is to replace it or have it replaced.
SOURCE: Maytag Neptune bearing noise
John,
What are the first two numbers of your serial number i.e.10 through 17. I’m an owner like you not a repair person….. but I have a very good feel for machine issues and the repair of the machine. See my ratings under this nick name FAV6800AWDIY and my old original nick name dh1200s.
The biggest problem with FIXYA is they don’t ask the user for Model or S/N of the machine. I can’t believe how many professional repair folks jump in with comments and they have no clue as to what machine is being discussed.
You may end up going with a replacement if it’s the Outer Tub Bearings. I would remove the tub and try to replace before I would junk a $1000 but that’s me you would need to decide. This a weak repair area for me I have not replaced the outer tub bearings on any of the three FAV66800A’s I own but I feel confident I could do it. I buy these cheap and repair for resale.
Have you had the Clutch Pulley removed/replaced in the past for dC or uC error code failure in Spin Cycle?
I would drop the Clutch Pulley out and clean up/re-lube the One-Way Roller Clutches and check for signs of a tub seal leak. Then with the Clutch Pulley out spin up the Wash Basket CCW as fast as you can by hand and listen for bearing noise of the Outer Tub Bearings. Let’s make sure the One-Way Roller clutch bearing is not the bearing noise source. See this post for removing the clutch and doing maintenance and replacement. Clutch Fix Post
I have to post rest of this comment as a comment. This forum is not geared up for DIY responses.
SOURCE: Where is battery located for Life Fitness 9500HR
These units are not self generating unit theirpower cords is in front bottom if it is missing then you will a power module got to www.sportsmith.net goto life fitness and get pricing
SOURCE: front drive shaft has a bad grinding noise and the
Found a website that builds brand new drive shafts with spicer u-joints for a reasonable price
http://www.alldrivelines.com/Jeep.html
