SOURCE: Charging of the casio exilim battery
Blinking light means charging error. Call tech support and they will replace battery for you for free.
SOURCE: Battery charger(BC-11L)
Battery charger will not hold its charge. the red light keeps blinking
SOURCE: charger
I am posting an answer to my own question... I called Casio Customer Service and gave them the model # and problem. They instantly sent me out a brand new battery. Turns out they have had a lot of problems with these batteries and will replace them absolutely free of charge.
SOURCE: My Casio Exilim EX-S880 wont charge.
I had this exact same problem. Here's a solution. I had to do it about 7 times and others on Amazon said they had to do it about 20 times. But it does work! My light is a solid red as we speak! Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
SOURCE: charger light blinks red never
Worx has had issues with their chargers and their batteries. They don't seem to last as long as the machine does. A simple voltmeter test of the charger and any battery will tell the story. The charger's output rating should be printed on it and the battery also. Touch test leads from voltmeter to the two and check.
