Hello, Phyllis -
Fixya.com does not sell air fryers or anything else, for that matter.
You will need to look on the air fryer to find the brand name and check the warranty information which is probably printed in the user manual which came with the air fryer. There may be information in the user manual regarding authorized repair centers for your air fryer brand. I hope you saved the manual and know where you stored it.
Best wishes.
SOURCE: My blower only works on setting 123 + air con not that cold
You have a resistor array assembly going out. What you described is typical of the first resistor going out and over loading the second, which goes out and overloads the third. Replace the HVAC resistor array. Don't buy a used one. Spend the extra money on the new OEM dealer item. Good luck to you.
SOURCE: I have bought 2 fryers within a year and a half
This problem cannot be fixed. For the second time, the wires to the switch burned right out and cannot be fixed. I have to buy a new fryer again.
SOURCE: F519-ORB stopped working
the first thing i would check is the wire connections under the cover at celing possible loose connection check wire nuts be carful turn power off befor serviceing ps dumb question is the switch on
SOURCE: How do I recharge the air condition on my 2000 nissan frontier?
If it needs to be charged,it has a leak & is poluting
the atmosphere
Therfore it need to be leak tested,system repaired,
a vacuum pump attached & the system vacuumed
dry,then properly recharged
You have no way to add & know what is in there
or being put in
You need A/C Manifold Gauges just to check the system
operation & charge correctly.
Charging may not be the issue at all
Need it diagnosed by a person train in A/C repair
SOURCE: Deep Fryer Element Won't Heat Up
Look for the reset button and it should come back on. I just did and lights came on immediately.
