NOTE: After removing the bin and defrosting the ice build-up it works again, but after a few days the build-up returns.
SOURCE: Replacing Auger in ice maker
Kim There are two Screws Holding the Complete Ice unit in Place,After Removing it it unpluggs inside the freezer,It would be advised to Replace the whole Unit ttech
SOURCE: Ice maker auger not turning
WELL DID YOU GET THE PLUG OUT OR END UP CALLING SERVICE ?AND FOR MY HONESTLY GOOD OPINION AND TRUTH IN ADVISING YOU!
YOU GAVE ME AN INAPPROPRIATE RATING AT FIXYA.COM
Shame on you! I know, sometimes the truth hurts!
BLESS YOU ANYWAY NGFAM1
There are many parts in this component that may be the culprit .
One or more will need to be replaced.
This is not easy to diagnose. I've seen service order parts 2 or 3 times till they completed the ice maker repair on a side by side fridge!
You need a hands on tech for this repair!
SOURCE: Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
SOURCE: Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
SOURCE: How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
