Answer was to replace reed valves. I have replaced the valve head, so this can not be the problem
Pressure switch
Testimonial: "Thanks so much"
Indicates reed/ poppet valve problem
possibly a broken spring in a head
Testimonial: "Valve head has been replaced, so it can not be the reed valves."
slow pressure build up indicates several problem areas
the air is being passed between heads or if a single cylinder in and out past faulty valve operation
the non return valve is passing air back to the cylinders
there is an air leak in the control switch diaphragm
next there is a ring problem and the air is passing to the sump and out by the sump vent
SOURCE: My compressor doesn't build enough pessure.
SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT. NOT TURNED OR FLIPPED OVER.
SOURCE: i have a 5 gal, i hp craftsmen compressor, 3 years
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
SOURCE: I have a Craftsman model 919.152932 33 gal
Sounds like the reed valves in the head failed. you need to replace the head (usually cheaper to get a new compressor)
Testimonial: "I hated to throw away an otherwise perfect condition compressor, but I had a feeling that was going to be the answer.Thanks for your help."
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
how-to-check-capacitor
