SOURCE: The TV power button on the remote supplied with my
yes -- you can buy a new or rebuilt remote that is the same item
SOURCE: My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
SOURCE: No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
SOURCE: My CH DVD player is about 10 years old. I can't
Unscrew the casing and take it out from there. By the sounds of it your dvd has bitten the dust so it wont matter much about damaging it anymore than it is already
Testimonial: "You confirmed my fears. Thank you."
