The exact mix ratio for Cub Cadet trimmers varies, depending upon the exact model. Cub Cadet's ST 228 2-cycle trimmer model uses a mix of 2.6 fluid ounces of 2-cycle oil blended with 1 gallon of unleaded gasoline or a 50-to-1 ratio. This equates to 20 milliliters of 2-cycle oil to 1 liter of gas. The Cub Cadet BC 210, on the other hand, requires a mix ratio of 40 to 1, or 3.2 fluid ounces of 2-cycle engine oil to 1 gallon of unleaded gasoline
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
SOURCE: HOW TO GET BRUSH CUTTER OFF FS 55
Look at the top of the head (where the brush cutter is) find the small hole about 3/16 diameter. Insert an allen wrench or a large nail, or anything else that will fit in the hole almost the same size as the hole. While putting a little downward pressure on this "tool" turn you blade slowly by hand until you feel the tool slide into the locking slot, this will hold the blade from turning. Keeping it in this position, take a socket and ratchet on the nut that is holding the blade and loosen and remove it. THE NUT HAS LEFT HAND THREADS SO TURN IT OPPOSITE OF WHAT YOU NORMALLY WOULD TO REMOVE IT!!!!
SOURCE: oil to gas ratio in
Hi, 25 to 1 with normal 2 stroke oil or 50 to 1 with stihl 2 stroke oil. Regards Phil.
Testimonial: "thanks for the help and speed reply rrh"
SOURCE: What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
SOURCE: what is the correct fuel to oil ratio for a 535RXT brush cutter
john,i have answered this how many times?? 50 to 1 unless the plugs foul then use 40 to 1
