After a little while it just beeps and the lights come on including a flashing spanner symbol. It isn't an unbalanced load I know about that and have fixed that before. It. Just sounds like a quiet whine. Nothing is ceased.
SOURCE: fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
SOURCE: Fisher & paykel top load washing machine
We had the same problem with our washing machine being full of water and beeping during the rinse cycle. The problem is that the filter, which is located under the washing machine, is plugged with something. Ours was plugged with a cotton swab. You have to tip the washing machine up and remove the filter and unplug it. The filter is in the center of the bottom of the machine. It twists off. I had to get the cotton swab out of inside the machine through this opening.
This machine plugs up a lot - I've never experience this with any other washing machine. Good Luck!
SOURCE: Start up Fault
there should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker. Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
SOURCE: my fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
