SOURCE: 2001 GMC Sierra Power Window problem
you should check the wire harness that goes from the door to the truck there must be a bad conection near by there somewhere in the harness hope this could help you.
SOURCE: driver side door stuck shut..willnot open
Take it to the Honda dealer, they will fix it for free, known problem and under factory warrenty.
SOURCE: 2005 chevy impala rear driver power window stopped going up.stuck
If neither switch works it is a bad connection at the motor or bad ground or a bad motor. Remove the door panel unplug the motor push the switch and see if there is 12volts on the wires if there is the motor is bad There are small brushes in the motor that go bad tap on the motor while pushing the switch if it works that way replace it
SOURCE: power window problems!!!!! window stuck down and it looks like
use the switch from the other side connect just use it and unplug it..it the switch does not work go to motor
SOURCE: some of the controls on the drivers side door do not work
Could be a relay..
Hope this helps !!
