Cannot unlock the tv to allow channel search. Caan open all the menu excpt the tv. Have the PW and it doeswork except for the chanel search
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: Can't watch dvds with my dvd player
Try two different things 1) on some of these tv's you could try pressing 00 to see if it will put you in input mode or 2) with your remote you should be able to push the input or tv/video to go to the input selection . In both of the above make sure you push the tv button first then step 1 or 2 . Good luck
SOURCE: samsung tv
as far as it turning off on its own I would get a fan on it and see if that make a difference make sure that the fan is able to flow around the tv especially through the back of it, if this stops it from turning off then it is an overheating problem
SOURCE: iLO LCD Color HDTV does not change channels / volumn...just turns on/off
I recently bought an ILO 32 HDTV with the same problem. I searched every site I could find for a solution. I finally found someone that gave me the direction to replace the Main Board for the TV. This is the board that you can plug your exteranl devices into, computer, dvd, HDMI etc.
The phone # to Digital Age is 909-974-2859. These are the people who can send you the part you need. Also the remote that I have is RC-500, which is the newest remote control for the new Main Board. I would suggest getting this remote.
The price of the board was $123.89 with $10.00 shipping. It only took 4 days to get the board from Ontario California, and yes they do speak english.
I removed the backpanel myself and then removed the metal cover over the Main Board. Remember to mark all of your wires and screws so you can put them back in the same location. The connections are all quick disconnects and the board is one piece. I had the board replaced and the back panel back on within an hour. All buttons working on the TV and the remote control, and the TV is working great with sound.
But I do not have the Manual......does anyone have the manual? I am willing to help anyone with a fix for their TV for a copy of the TV Manual.
I hope the information I have given helps in anyway possible,
Johnny
SOURCE: LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
SOURCE: Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
