Proscan Model # PLDED4331A SN# A1509149270002032
SOURCE: proscan tv
enter the user menu to see if you have text or telecaption on,if not your vertical section is possible at fault if the bottom half of the screen is blacked out.
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
SOURCE: video problem on my Proscan LCD TV.
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
SOURCE: Proscan tv keep blinking
I would say it is your power board capacitors that have failed. Easy cheap fix if you can solder.
