The ground has water from the Blodgett leaking. I think it coming from leaking thru the oven door
SOURCE: athens controls inc board for old blodgett oven (gas)
Athena still sells this product as a ttc001
call me at 610-729-1032
SOURCE: What do you replace to
Hello
Open the door. There are two essential components here: the latch itself, and the striker plate. The latch is the thing that's connected to the doorknob, and the striker plate is the metal part in the door jamb.
If the door isn't latching properly, then the latch isn't properly lined up with the striker plate. You must now determine how they are misaligned. Crouch down and slowly close the door, looking at the latch. Is the latch too high or too low? If not, then it's likely not lining up left-right.
Once you've determined how the latch is misaligned, simply use the metal file and file down the hole in the striker plate until the door successfully latches. You may need to use the chisel to remove some wood from the hole, as well. Keep trying to close the door until it repeatedly latches properly.
If it's very misaligned, it may be better to reinstall the striker plate. Simply unscrew the screws to remove the plate, and then re-install the plate where it needs to be.
