Nobody, On September 13, 2009, Protron Digital Corporation went out of business as per its Chapter 7 liquidation filing under bankruptcy. Protron Digital Corporation manufactured sound products and digital electronic entertainment systems in the United States.
Now you can find this product on Amazon, but it uses its own brand of sellers.
SOURCE: Protron PD-800 DVD player
On the remote control of the DVD player, just press the P-scan, reset or video SW button.. That would fix it... If you have screen kumping problem then please try this following steps... Press the setup Down arrow once Enter Down arrow 1 time Enter Up arrow 1 Enter Set up
SOURCE: protron pd-007
I finally, after several months of just giving up, figured out how to get my Protron 007 DVD player to work. I hope this works for you. I have a Sanyo TV with the video controls on the front. Here are the instructions that worked for me.
1. Turn on TV
2. switch TV to video
3. Wait for "Protron" screen (Try the PSCAN button it doesn't show.)
4. Press setup and a menu will appear with 4 icons: Language, TV, a Hammer, and an Exit icon.
5. The only two icons I needed to use were TV and the Hammer.
6. TV icon: 4 choices: a) TV TYPE = choose 4.3 LB (mine was not set there); b) TV SYSTEM = NTSC; c) VIDEO = CBBS + S - video; d) DIGITAL OUT = SPDIF/RAW.
7. HAMMER icon: 4 choices: a) PARENTAL - 8; b) PASSWORD - I didn't choose one; c) ANGLE MARK: ON; d) DEFAULT: Read.
Suggestion: If that doesn't work trying playing around with the settings to see if you can get the right combination.
I hope I made your day. I know how frustrating this can be.
Jane
SOURCE: Remote Control code for DVD Protron PD-800
The code I used and it seems to work is 0194, but while trying to program my receiver, It changed some setting and the picture keeps looping over and over on the screen, and I can't get it to stop, I even made it worse while messing with the settings....
SOURCE: no video to my tv just the sound
Check if you do not activate by mistake the progresive scan function
SOURCE: protron PD-DVR100
The original remote is no longer available, but a substitute is at
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12681959986730&smodel=PDDVR100&brand_pn=PROTRON_PDDVR100
You can download the user manual at
http://www.retrevo.com/support/SpectronIQ-PD-DVR-100-DVD-Players-manual/id/926dj289/t/2/
Please rate this solution. Thanks.
