SOURCE: Loud noise when draining and spinning
It sounds like it has something to do with the pump which can be located in the direction of the noise. It could be something as simple as the belt wearing out or even just the pump came loose off of its mounts. Worst case scenario would be a new pump but it honestly sounds like something a little less intrusive. I know I had one that I had to hold down with a bungee cord because the mount had broken off of it.
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
SOURCE: Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
SOURCE: ftf2140es3 won't completely drain or do final spin.
I have one that does the same thing at times. remove the bottom front panel. You will see a black boot that comes down from the tub. Loosen the clamp on top of the boot. You should be able to pinch the boot and feel something hard inside the boot. Pull the boot down from the tub and put your fingers down inside the boot and pull up the coin collector. It may be full of junk, coins ect. Clean it and replace the boot and clamp. This should help you.
