SOURCE: power switch will not work
Hoover U6437-900 U6439-900 Windtunnel Upright
seems there is a short in the power switch, is that possible, I have it disassembled and seems there is power going into the on/off button, but will only sporadically turn on
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This could be a defective switch or it could be a loose connection or wire – chances are that it is a defective switch and needs replacement – this could be a slider switch of which does wear out and that is why it will comes on sporadically – if there is a local vacuum cleaner shop in your area they can test the switch and possibly sell you a new one
http://www.hoover.com
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
SOURCE: Frigidaire crown series dryer no power
bad thermal fuse
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
SOURCE: The fault light immediately comes on my Crown XLS
Hi try disconnecting the speaker outs and turn off bridge (if its on) If it doesnt work still, then suggest direct to a crown agent. The amp has a 3 year no fault warranty. Hopefully its still in!
All the best
SOURCE: No power to Crown XLS 602 Amplifier
Hi...
There may be some internal fuses on that unit.
You can open it by taking the cover off and looking for fuses and discolored parts.
It may have a thermal fuse on the power transformer which then will require service
Check the web for service people in the UK
CONDITION: No
power to the amplifier.
POSSIBLE REASON:
• The amplifier's Power switch is off.
• The amplifier is not plugged into the power receptacle.
• The amplifier's high-voltage power supply circuit breaker has tripped. Verify that the AC mains
voltage is correct, then press the Circuit Breaker button on the back panel.
Take it to the ER.
