SOURCE: trouble pairing my bluetooth Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
SOURCE: need code to pair my technocel bluetooth
If you haven't found it yet, use 0000. If this is helpful, please post as such. If it fixed it please post as fixya
SOURCE: LOGITECH BLUETOOTH MOUSE
Normal
0
Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth
Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard
(Usually located on the under side of your keyboard) this allows Windows to see
the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To
Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device
Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and
click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth
Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if
you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back
and click Next again.
Once the Passkey is entered, the Keyboard should be
connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
SOURCE: I'm being prompted for a pairing code for my MS
Most common after the 0000 is 1111 or 1234. One of these should work for you. If it does let the community know by giving me a rating.
SOURCE: My computer is asking for the pairing code for
You can enter 0000 for the code.
I took this straight from targus's support answer to this problem.
