20 Most Recent Logitech M-RBB93 Mouse Questions & Answers
I need a pairing code for a Logitech Bluetooth mouse M-RBB93
If the mouse refuse to connect, you should delete it from your Devices, then re-add. (for exact directions, Weldon Dube below has awesome step by step directions)When it comes to paring, it uses the basic paring code of 0000 (4 zeros)
9/18/2019 9:24:25 AM • Logitech M-RBB93... • Answered on Sep 18, 2019
0answers
0answers
0answers
2answers
My M-RBB93 logitech mouse is recognized but before
This is such ****. What a waste of time. Logitech sucks. Spent hours trying to research this. Logitech manuals and FAQs provide no help.Want to pair your crappy Logitech Bluetooth mouse with your laptop/PC? Going crazy trying to find your "pairing code"? Try this: "0000" (four zeroes)!
4/10/2012 10:30:53 PM • Logitech M-RBB93... • Answered on Apr 10, 2012
How to solve when usb mouse driver is corrupted in windows 7
Morning to youI would uninstall the mouse and see what happens else it is the manual.good luckkolbrun
2/24/2012 7:42:00 AM • Logitech M-RBB93... • Answered on Feb 24, 2012
My mouse just stoped working
Replace the batteries then try reconnecting it again.
Please rate 4 if this solved your problems.
4/26/2011 3:32:00 AM • Logitech M-RBB93... • Answered on Apr 26, 2011
2answers
Logitech wireless combo mouse keyboard mk220 support through bluetooth
• Check the orientation of the batteries inside the keyboard and mouse, or replace the batteries. • Is the USB receiver securely plugged into a computer USB port? Try moving the USB receiver to a USB port closer to the keyboard and mouse. • If the USB receiver is plugged into a USB hub, try plugging it directly into your computer. • Remove any metal object between the receiver and the keyboard/mouse that may interfere with reception. Try using the mouse on a different surface. • Restart the computer. • If these suggestions don't work, download the Reconnection Utility from http://www.logitech.com/connect_utility.
2/28/2024 3:07:39 PM • Logitech... • Answered on Feb 28, 2024
Does the Logitech cordless mouse have data in it
Of course not. It is a simple I/O (input output) device. It stores no data. ..
2/3/2024 5:55:00 AM • Logitech... • Answered on Feb 03, 2024
How i can connect my logitech wireless mouse EN60950 to the laptop
Unfortunately, EN 60950 is not a Logitech model number. It indicates that the mouse (or other electronic product) was tested and met the European IEC 60950 standard. Here's a copy of a Logitech EN60950 certificate: https://www.logitech.com/images/pdf/compliance/AGY-700-018651.001_AGY%20CERT%20CB%20HS%20A00086%20BAER%20CI%20(GGEC)_EUROPE.pdf . Logitech sells several different wireless mice types. Some connect to Bluetooth only. Some connect with a specific USB wireless transmitter/receiver. The dongle is small enough to fit inside the mouse's battery compartment or stay in a USB port when the laptop is moved. (Older Logitech devices used the Unifying USB wi-fi adapter; new ones use the Bolt adapter.) A few models can be used with both Bluetooth and one of the wireless adapters. These can connect to two or more devices and then a single button switches between devices. Please try to find the actual model of the mouse to get the correct information for connecting the mouse. Logitech support may be able to sell you the USB dongle if they have the correct one in stock. I hope this helps. Cindy Wells
12/8/2023 11:47:00 PM • Logitech... • Answered on Dec 08, 2023
Need help with Logitech DiNovo keyboardmodel Y-RAY81 that is not flashing green light when put it on the charging base.
When charged, the green light does not flash. However, since you mentioned that the old battery is also not flashing any light, it could indicate that there might be some issues with the charging base or the keyboard itself. Here is a link to some troubleshooting steps to take. But if they do not work, your next step is to contact Logitech support. Troubleshoot keyboard connection issues - Logitech Support + Download
10/29/2023 11:39:54 AM • Logitech... • Answered on Oct 29, 2023
Logitech M-RBB93 Mouse Logo
21 questions posted
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Computers & Internet
Most Popular Question
m rbb93 logitech mouse recognized but
  • Computers & Internet
