SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
SOURCE: I need the gap setting for the coil on my homelite
As small as you can without fouling the flywheel. It should work with anything up to a 20 thou gap, so if you set it to 10 thou and no spark, then you need to replace the coil..
