What about the front right turn signal, does it work when the rear doesn't? My guess is, it doesn't work either? The lower brake lites and turn signals may use the same bulb filament, but, not at the same time and are wired through the turn signal switch. Have you tried a new bulb, Is the bulb socket ok? You may need to check turn signal switch and wiring. If there is an air-bag in your steering wheel, you need to be careful, you don't want it to blow up in your face. Safety is your responsibility.
SOURCE: Chev Cavalier 2003 only one rear turn/brake/hazard light
I have a 2002 Chev Cavalier that had the same exact problem. I replaced the bulb harness (purchased from a chevy dealership for around $5) which was fairly easy to do. I have had zero problems with it since.
SOURCE: Brake light, Turn signal not working rear right 06' Focus
I have a 2000 ford focus no brake lights. with the brake lights the transmission would not go into drive .replaced the brake light switch checked fuse replaced turn signal switch with no results then i moved onto the wiper switch and replaced it as much to my supp rise it fixed the problems
SOURCE: parking lights work third brake light works,just not back brakes?
The bulbs do not need to be replaced! The answer to this problem is believe it or not in the turn signal lever, or multi-function switch. It is extremely common on these cars, and usually mis-diagnosed. Try this before going any farther. Back the vehicle up to a wall, or have a person stand behind the car, and pull the turn signal lever slightly towards you as if you were switching between hi and low beams. I guarantee that when you put just a little pressure on the lever your brake lights will work. If you want the problem fixed, you need to have the switch (and lever arm) replaced from inside the steering column, and you need someone to remove the airbag to do this. The switch is roughly $200 from an aftermarket parts store. If you learn to drive your car and just know that when you brake you can pull back on the lever to make the lights work great, I did for a few years in mine. But I guarantee that is the answer to your problem
SOURCE: rear left and right turn signal lights not working.
the electronic flasher module may be faulty, or you could have blown a fuse
Turn signal tail lights and BRAKE LIGHTS NOT WORKING
It
can be faulty brake light switch causing the problem or its blown brake light bulb.
First check and confirm brake light lamp is working and that's not
the case.
For turn signal not working it can be faulty turn signal switch or its issue with wiring:----
To
trouble shoot brake and turn signal related problem, check the help links mentioned
below:-----
Click
the link:----
1996 Buick Regal Grand Sport Brake light
Switch Location?
http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
No brake lights on Buick?
http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
Brake lights not working on 1989 BUICK REGAL?
http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
How to replace Brake light switch on Chevrolet Tahoe?
http://technoanswers.blogspot.in/2012/02/how-to-replace-brake-light-switch-on.html
How to
replace Parking, turn, and Brake Lights on car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-parking-turn-and-brake.html
Upper brake lights work,
but low brake light not working?
http://schematicsdiagram.blogspot.com/2011/12/upper-brake-lights-workbut-low.html
1997 Cadillac Catera: How
to replace Brake Light Switch?
http://howtobyme.blogspot.in/2012/06/1997-cadillac-catera-how-to-replace.html
2003 Chevrolet S10 Tail light Fuse
http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light
Wiring diagram
http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Car Tail Lights Not Working?
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
Turn Signal Not working
http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Right turn signal not working on Pontiac Car?
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
Only one side indicator light working on car?
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
Turn signals not working on 1987 Jeep
Wagoneer?
http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
1996 Chrysler LHS brake light circuit wiring
diagram?
http://technoanswers.blogspot.in/2012/02/1996-chrysler-lhs-brake-light-circuit.html
How to replace rear Brake
lights on 2004 Toyota RAV4?
http://schematicsdiagram.blogspot.in/2012/02/how-to-replace-rear-brake-lights-on.html
One brake light on driver
side not working, but other lights work?
http://schematicsdiagram.blogspot.com/2011/12/one-brake-light-on-driver-side-not.html
2002 Lincoln Town car Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html
2007 KIA Rio: Brake Light Fuse Box
Diagram?
http://repairhelpcenter.blogspot.in/2012/06/2007-kia-rio-brake-light-fuse-box.html
Overhead Brake lights not working on 1999 GMC
Sierra 4x4?
http://technoanswers.blogspot.in/2012/03/overhead-brake-lights-not-working-on.html
2004 Ford Mustang: Brake
light Fuse Location?
http://howtobyme.blogspot.in/2012/05/2004-ford-mustang-brake-light-fuse.html
These
will help.
Thanks.
