SOURCE: Feed dogs not feeding material
Make sure that you did not disengage the feed dogs by accident. You should have some type of button that allows you to control the feed dogs.
SOURCE: Feed doesn't feed Singer 560
there should be a control to raise or lower the feed dogs, lower to stipple and high to sew normal. it sounds like you may have lowered them
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
SOURCE: The feed dogs will not move the material
check the feeddogs & see if there in the up position, if there not move the lever or knob to the up position
if the lever is up then there is something wrong with the feeddogs & it needs to be serviced
