My sunbeam XL heating pad started blinking and I couldn’t figure it out. I Unplugged a couple of times and still it kept flashing. After hours of reading post, I did what wpart suggested and now it works normal again..... I kept pushing th on off button while plugged in, I unplugged it while still hitting the on off button, I plugged it back in while still hitting the on off button annnddddd drum roll please!!!!!! It started working properly! Thanks wpart, your the MVP and award goes to you!
Https://www.amazon.com/ask/questions/TxXJ2JCKNOWESD?_encoding=UTF8&sort=helpful
Several people reported F could not be resolved. One suggested contacting the manufacturer using the form on its web site.
SOURCE: new heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
SOURCE: Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
SOURCE: my sunbeam matress heated pad only flashes F1 and
you either have a power issue or the pad will not go to higher levels because of a heating element issue within the pad its best to replace because if it continues or gets worse then you could be looking at a future fire or electric shock please be carefull and take the safe way and replace it!
SOURCE: Sunbeam dual control heated mattress
I have older sunbeam duel control matress pad. the control is simple with a dial that turnes for low or higher settings. it shows a red line that is small for low and gets thicker as the setting gets higher. there is a button for on and off. I set up the cover and turned on. the green on lite is flashing and there is no heat i do have it on high and it now will not turn off by the button.
SOURCE: my sunbeam heating pad model cat95c is flashing f
unplug replug blanket to control connectors plug back in
this will continue to happen on these blankets you will have to reset these blankets again and again (chinese junk)
