SOURCE: I have lost my manual to my GE Profile Gas Range, self cleaning, convection and conventional oven
what does f2 mean when I am self cleaning my ge profile oven.
SOURCE: Oven will not work
With a gas range, I wouldn't fool with it. Get a service man out there now! Gas stoves are great untill they malfuntion and need a qualified service person to check it out. It's cheep insurance if there is a gas leek causing the problem. The alternitive-------!
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
SOURCE: GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
SOURCE: ge xl44 self cleaning gas oven willnot come on
Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
