Wascomat EX618 Service Manual Page 136
Page 136 - Unfortunately, it suggests it may be necessary to change the CPU
SOURCE: Info Code 054 - Printer Error - cannot be found in manual
sorry to tell you its the lsu laser unit in the machine the only way to fix it is to replace the part
SOURCE: wascomat dryer error codes
Check the following link: http://www.laundrynation.com/manuals/wp-content/uploads/2011/05/wascomat_dryer_selecta_control_programming_manual.pdf
On page 13 it identifies the E 08 error as overheating air (inlet or outlet). Chances are, it is the outlet that has gotten gunked up from lint or other material. Pull the vent tube off, vacuum out lint traps, clean the outlet tube, reset the machine. If the dryer is linked with other dryers on a multiple-link vent system, cleaning the vent lines may be necessary to avoid the problem.
could be the heating element, error one is mainly this though but a fault with the heating element can do the same
This error code is generated by the CPU board.
When filling with water, the level specified by the wash program must be
attained within a certain time. This time is normally set to 10 minutes but
can vary depending on the type of machine and the software. If the filling
time eceeds the maximum allowed filling time, error code 01 will be dis-
played.
Long filling times can be caused by a blocked filler valve, defective filler
valve, a break in the cable between the filler valve control board, defective
valve control board, leaking level system, etc.
