Minn Kota Riptide St Saltwater 55 Bow Mount Trolling Motor Logo
Posted on Jul 30, 2009
Just purchased 2 Optima 900 CCA Marine Batteries, installed if I go to full throttle on the Riptide Saltwater 80 the throttle gets really hot as well as the cord. Is their a maximum amperage rating that you can use so you don't damage the unit.
  • Anonymous May 11, 2010
    do you have both batteries connected to the 1 motor ? if so that might be where your problem is
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Jul 30, 2009
Anonymous
Contributor
Level 1:
Answers
26
Questions
0
Helped
12771
Points
69
Check for a short in the wire. make sure that positive and negative are right, if unit was working before old battery went bad.are batteries run in series or are they separate. if they are in series make sure they are installed correctly.
The turn feature on my remote trolling motor will not work
Maybe the pin is sheated on the prop...or something is caught in it..
check the prop.
I have a minkk kota riptide salt water bow mount trolling motor. The motor functioned properly last time out. This time the motor failed to come on. one of the batteries was found to be bad and...
Many times on the battery lead, actually the part that tightens to the battery, has a circuit breaker. You will notice a small reset button on each positive lead....of course there are two for a 24v system. Reset each one!
I have a Minnkota Riptide 80# thrust trollmotor.I have power to the head but motor will not run. It is a bow mount with twist grip control.When I mash on the power indicator button ,it lights up showing I...
1. possibly a broken connection to the motor where the propeller is located. 2. Also could be a bad motor. 3. Look for a fuse location for a possible blown fuse to the motor. 4. motor brushes could be the problem.
Stuck in gear forward will not shift into any other gear
possiblty a shorted power transister in the speed controller.
Online manual needed
I have minnkota riptide i had to take the handle off and a little spring & white plastic piece poped out of the handle i just wanted to see where it goes
2answers
Bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
2helpful
How to install trolling motor
If it is a bow mount model, then you basically need a bow mount bracket attached to the bow of your boat. If one didn't come with the outboard, you will have to buy one from the same manufacturer or an after-market one suitable for your boat. If in doubt, consult the local boating or marine store or wherever you purchased the motor or the bracket from.
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
