That's it.
SOURCE: nike triax speed WR0082 regular
You must Re-Link the SDM pod to the watch after changing the battery. Go to the link below, It's not the exact model, but, should work, if not, go to www.nike.com and download the manual for your model.
GOOD LUCK
http://www.nike.com/timing/extranet/product/triax_elite/elite_manual_eng.pdf
SOURCE: eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
SOURCE: I HAVE A CELEBRITY DX SCOOTER,
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
SOURCE: PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
SOURCE: Hi My Suunto Vector watch battery expired a few
Contact the manufacturer to see what battery they recommend. They should be able to tell you which they used originally.
