Can I get extra keys for padlock set, key # 02770
Any locksmith should be able to cut you replacement keys. I cannot verify it, but the key code is likely the actual cuts of the key, and so it will be easy to cut them. If not, the locksmith may have to use the code to look up the cuts, which may cost a bit more. Even then, it will still likely be cheaper than trying to have them mailed from the manufacturer.
