SOURCE: Can I use a Chrysler/Infinity amp with aftermarker JVC radio?
it wouldn't be advised unless there are rca connections into the amp. these are the same as the inputs in the back of the jvc. It is possible to connect into an amplifier using speaker cable but i wouldn;t advise doing this unless you know what your doing.
SOURCE: aftermarket installation of head unit in 97 jeep grand cherokee
well, if you go to crutchfield.com you can find everything you need for way cheaper than a 100bucks. i own the same jeep and have installed everything without bypassing my amp..it sounds great. just check that site out and give them a call. they will hook you up
SOURCE: 05 dodge ram with infinity system amp turn?
There is two ways you can do this you can find the turn on wire for the amp and hook it up to the amp turn on wire from the radio (this is the bootleg way and sound might cutout when you turn the radio up)
The best way to go is to go to best buy or your local sound shop and get a bypass harness for a dodge infinity system(go this way so you won't have rny problems)
SOURCE: NEED STEREO WIRE COLORS FOR 1988 BMW 735I
red = constant live 12v
brown = negative ground
violet = ignition live 12v
white = electric antenna (rear screen)
the speakers will be twisted pairs, i can not remember which is left and right but the grey stipe and brown strip are negative the others are positive.
If in doubt get a pro to install for you as you could cause damage if you connect wrongly.
SOURCE: need wiring diagram for a 2002 mustang Mach 1
2002 Ford Mustang Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Purple/Light Blue
Radio Switched 12V+ Wire: Black/Pink
Radio Ground Wire: Black/Light Green, Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Light Blue
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
