I think the lED strips as I hooked a pc to it at white screen in a dark room I saw the LEDS were not lighting correctly so I will go that route
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
SOURCE: no picture power ups blacklights work no menu no
If you see the back light, then you should have 24vdc on the main power supply board which it gets the turn on command from the maun board. If you do have all those voltage, then it does sound like you need the new main board.
SOURCE: Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
SOURCE: vizio VA 26 L HDTV10A black screen after on for 3
There remains only the fluorescent back light tube(s) or the inverter that supplies high voltage for it (them). If you had no warning flickering, I would look for the inverter board.
If the backlights lamps are bad, you will not get picture but will still have sound. Lamps (est. life of 50k hours) are rarely goes out, its electronics that go out first. I do not think the person you talk too ever work on the LCD TV.
More liekly that the 12v (for sound) and the 24vdc (for backlights) power supply section is not working.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
