Smeg washer saws 1014
SOURCE: Maytag Neptune TL Washer
if this worked fine before, then I am only guessing that the water inlet valve has malfunctioned. try filling the machine with a garden hose...any change? if still no go, then be sure to have a shop-vac handy to remove the water you just added.
SOURCE: Error Codes
This error is an EEPROM communication failure of the electronic control board .Basically indicates the washer no longer thinks any more as washer.
Repair requires the board to be replaced. ..But be careful so that you get the right control board.
SOURCE: I get an F09 error
"F09" is an Overflow Condition error. The following link explains:
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
The first thing to try is to unplug the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). In some cases this is all that it takes to correct momentary glitches with the unit. If the error code reappears, follow the guidance I provided you.
This is one of those challenging errors to identify sometimes. Start with the easy possibilities, first. In addition, your washer should have a tech sheet inside to assist in component identification and troubleshooting. You can access the tech sheet by removing the lower panel under the door. If the its not taped to the back of the lower panel, it will be located along the interior wall of the cabinet.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
SOURCE: Pushed pause. Added garment. Washer will not start again.
possible you have not held "start" button down for the required 5 sedonds to restart cycle??
