SOURCE: kenmore 80 series washer not completly spinning clothes dry
Belt going..
A bit of a pain to replace, but doable..
Belt dressing will keep it going for a while..
Dont get your fingers caught in it..
Serious injury is possible, unplug the machine
and stand on the plug while moving the
belt to goop it..
(why? that way it cant get plugged in!)
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
SOURCE: spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
SOURCE: spin cycle is not getting
When the clothes are wet at the end of a cycle, check these: Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
SOURCE: Tricity Bendix BIW 105W Washing Machine
on a bendix 105w if you set spin programme(15) the pump comes on for 10 seconds then nothing, the belt is ok. on other programmes it washes and rinses as normal, just wont spin. help!!!
