We have a Becken ceramic cooktop that we locked earlier(with pressing the little key). Now the little key is read but it's beeping at longer intervals. We cannot turn it off or on. Pressing on/off or key "button" long time doesn't help What can we do?
SOURCE: Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
SOURCE: need help to unlock the cooktop
You will have to hold the lock button down for 3 or 5 seconds for it to unlock. If this doesn't help, it could be a stuck key pad or a problem in the circuit board.
Thanks/Mike
SOURCE: Whirlpool Gold ceramic cooktop removal.
the safest way for a home owner to do this is turn the main breaker off to the house that is the safest way. Then poll the cover plate off the box in th wall with the two screws. not the screws on the round conduit. Then pull out the wire nuts that hold the wires together and un screw them to separate wires I would label them so you know what ones went together. After top is in just reverse the proses above.
SOURCE: THE LOCK INDICATOR FLASHES WHEN THE
hi my name is mark have tried to hold the on button down for 10 seconds. sometimes that unlocks controls.hope that helps.
SOURCE: Wolf cooktop 5HR light keeps turning on. Pressing
Turn off power to the cooktop (i.e., using circuit breaker if needed) for 15-20 minutes. Once turned power back on, problem disappeared for me. The semiconductor needed to be reset
