OE in red lrtters on machine front
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Posted on Oct 29, 2017
SOURCE: OE error code
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
best of luck...........
Posted on May 06, 2009
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
SOURCE: my LG front load washing machine is reading OE...
oe is drain error, which means that the machine is slow/or not emptying..Most likely you have to clean the pump filter...This is accessed via the small door at floor level..Unscrew the pump cover andclean the filter...Remember that any water will drain from the machine from here, unless the machine is empty...Leaning the machine back can help...Good luck...Nomess
Posted on May 22, 2010
Nov 20, 2017 | LG Washing Machines
Aug 29, 2015 | LG Washing Machines
Aug 12, 2011 | LG WM2277H Front Load Washer
Dec 18, 2010 | LG WM1814CW Front Load Washer
Sep 03, 2010 | LG WM0642H Front Load
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
May 29, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
May 20, 2010 | Washing Machines
Apr 28, 2009 | LG WM-2277HW Front Load Washer
Oct 02, 2008 | LG Washing Machines
314 people viewed this question
