John Hanner Posted on Oct 22, 2017
I have a vivitek 5080 projector the lamp comes on but doesn't recognize anything plugged into hdmi slots,what can I do to fix it?
5 Related Answers
A
Anonymous
  • Posted on May 10, 2008
SOURCE: Mitsubishi xl2u projector
I ended up sending it to Mitsubishi Service center for repair. The technician said it was the power supply and it now works so I'm happy.
Anonymous
  • 4 Answers
  • Posted on Jan 27, 2011
SOURCE: Have replaced projector bulb,can not reset lamptimer
turn the tv ON: On the side of the TV press the menu and volume up buttons at the same time for three seconds. The 'reset lamp timer?' will appear on the screen. Press the OK button to accept. You're done!
rickbrashear
Ricky brashear
  • 176 Answers
  • Posted on Aug 11, 2011
SOURCE: Projector powers up as normal, bulb comes on,
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
caroldon
  • 17130 Answers
  • Posted on Sep 28, 2011
SOURCE: my vivitek d510 projector lamp is not turn on.
You need to check the power supply feed to the lamp circuit and if this is workingg fine check if there is lamp reset- hours used. Also if the filter is blocked remove and clean, check the fan and also the connections/connectors in the mother board.
If not there can be errors in the motherboard.
Jerome Holmes
  • 3 Answers
  • Posted on May 21, 2013
SOURCE: my projector won't project anything.
I have the same proble with my CP-S318 Hitachi except ut does show the logo but will not detect any connection.
Change module on Vivitek projector
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Vivitek d511 showing grid lines on image
the interface between the mother board and DMD drive board
to clean the the interface with some alcohol
securely plugged
ok
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
1helpful
My vivitek d510 projector lamp is not turn on.
2answers
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
2answers
Source not found I am using an Acer Aspire One
Make sure you are using ports other than the USB port. Vivitek Service indicates that at least some of their projectors do not use the USB port for input. "The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service
Hope this helps.
We have connected both the cables (VGA and HDMI) in the Vivitek D945VX but when we use just one cable VGA or HDMI at a time to display through Laptop, the projector would not display properly (sometime it...
you are using a long cord but this should not effect it.... try unplugging the cable you are not using from the projector and just have the one cable going from laptop straight to the projector... hope this was useful...
1helpful
I am needing to verify if this projector allows for a widescreen image and what type of bulb does it use?
hi,
vivitek D510 supports 16:9 ( wide screen) format also. it uses 180w projector lamp.
ok
Top Vivitek Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
Emmanuel Asiedu
Emmanuel Asiedu
Level 1 Expert
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
