Dear Rosemary Preater
1. Seems pdf file corrupted.
If it happening with all or most of the attached pdf file then might be a case that you have installed some anti-virus which corrupting the file for any reason.
If this is the case for you, then stop/disable the anti-virus and try again to get a new pdf file through the e-mail and test it.
If it works, then you have to talk your anti-virus supplier.
Thanks
SOURCE: can't open attachments
in your internet the popup for attachments is blockd it means new window it wil open so it can be showd in left down corner to get your pop up window your attachemnts can be shown
SOURCE: can't open yahoo email attachments
try clearing the browsing history in internet explorer options so it clears out the cookies just go to internet explorer options and click delete it should be under browsing history then try again it should then let you open attachments in yahoo
SOURCE: unable to open attachments sent via email
try updating the OS see if that helps if not then you may want to try reflashing the OS.
SOURCE: Adobe Reader could not open
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips:
Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
SOURCE: yahoo mail will not open pdf files
contact yahoo technical support
Testimonial: "yes this was most helpful i went onto the technical support on the internet and they have said there is an issue with downloading files at the moment and trying to rectify it, their answer doesn't explain why i can access the pdf files from another computer, maybe it has something to do with one having windows xp and mine having windows 7, don't know, but at least i know its not my computer, so yes thank for your help in this matter."
