Water Heaters Logo
M
Margaret Posted on Sep 17, 2017
Bosch water purifier cover keeps dripping water what tondo
Bosch aq 125 bng
sounds like pressure relief valve is stuck closed free of or replace
Water dripping from bosch water wizard 13b unit
you can rebuild the flow control valve to prevent this.there is also a new flow control valve that has supersceded some of the older ones.
I have a bosch 13p and the pilot light keeps going out I don't know if is the thermocouple or not as it stays alight for hours then dies. It is in a sheltered area and i have checked for blockage.
Get more air to the unit.
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
Don't use household vent fans.
Trim back trees, and move stuff away from front of water heater and from around vent pipe.
Pilot outage can be caused by tightly insulated house, poor upward draft on flue, other vents or vent fans drafting air upward and causing downdraft on water heater, wind coming down flue pipe, water dripping down flueway, dirty combustion parts, clogged pilot orifice, failed thermocouple, failed gas control valve, low gas pressure, water or air in gas line, super hot location ... or combination of more than 1 thing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Bosch 25E will not ignite to heat the water.
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
New gas bottles installed but hot water not working
You posted under Bosch tankless water heater.
The suspect is probably gas supply, gas valve, or gas related part inside tankless unit.
Before calling service technician, open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
My gwh 2700 keeps freezing at night,and takes about 2 to 3 mins to reach a warm temp. had it for a 2 years no problem. just started with freezing. how do i fix it.
Freezing water inside pipes can damage your water heater.
you should lag the pipes and if not fitted you should fit a cover to the pipework.
Is the unit outside? if so here is a link to a manual with some info on Bosch water heaters
http://www.boschhotwater.com/Portals/7/TechManuals/PipeCover_10.2009.pdf
My Bosch tankless hot water heater keeps turning off and I have to go out and reset it often. I go outside and the screen is flashing A30...I reset it and it works for a while and then it goes out again. ...
Open following link for Bosch tankless troubleshooting resources, including Bosch contact number and link for finding service technician, etc.
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Thanks!!
5helpful
Bosch Water Wizard 600 pilot light keeps going out
You need a new thermocouple. Its the little stick like thing that the flame heats up to tell gas valve to open.
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
