SOURCE: Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
SOURCE: Hi, My top loading kitchen aid
Your machine may have a coupling that has failed, this is a rubber and plastic coupling, designed to reduce noise. They fail and the machine will barely work... This is not a hard replacement. Open the machine and look near the motor.
SOURCE: Hi I have samsung top loader washing machine.Now i
the inner bowl has whats called a balance ring which means the top layer ring around bowl has water inside to keep washer balanced...this is perfectly normal
SOURCE: Hi! My 7kg Samsung J843
Hi, I've had this problem before. It was a while ago but it was either a broken belt or the belt had slipped from the correct position and needed to be put back on. It was under warranty and a service tech fixed it.
Testimonial: "Thanks! Yes that was problem. We weren't under warranty but it was still a lot cheaper to pay a guy than buy a new one!"
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
