20 Most Recent
Samsung 4.3 cu. ft. VRT Plus , Steam and PowerFoam Front Load Washer Questions & Answers
Door will not lock
The latch is either broken or has come loose. Check the latch to see if either applies.
How to reset the drain pump on Samsung vrt washer
The drain pump is not something that you can simply "reset". If the overload device has operated "open circuited" and has not reset itself after cooling down, it will have to be replaced. It is located between the motor coil and iron. However, if this is the case, it may mean that you have a serious problem with your motor. And to make matters worse, if you have a problem with your drain motor, it may cause problems in your Control Panel.
Why is my Samsung VRT Steam washer holding water in the detergent/softener dispenser?
the soap, bleach and fabric softner get dispensed by opening a water valve to the dispenser to flush out the items. They then flow to the bottom of the tub. Not all of the water comes out for various reasons, but the important information is that it is seldom critical to performance. If you want to pursue it, check dispenser (take it out) and clean it well. I assume the machine is level.
