Cameras Logo
D
Doreen Posted on Sep 02, 2017
My canon 70d does not zoom and focus automatically
JDSmall
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Sep 03, 2017
JDSmall
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
17828
Points
19
My guess is the self timer was accidently turned on
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
4 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Aug 01, 2007
SOURCE: canon powershot sd 1000
Canon Customer support re this I suspect the Zoom mechanism is damaged A rapair may be costly
Anonymous
  • 30 Answers
  • Posted on Oct 11, 2009
SOURCE: my canon eos rebel xt 350d wont focus
change your manual settings
Anonymous
  • Posted on Apr 26, 2010
SOURCE: Canon 15-55 zoom: won't auto focus. My 70-300 on
focus ring on cannon ef70-300 zoom is stiff, jerky. how can i free it up.
danhunt
  • 22 Answers
  • Posted on May 18, 2014
SOURCE: Where can I find a service manual repair guide for Canon EOS 70D?
Try here:
http://thydzik.com/downloads/canon-service-manual-eos-kiss-digital-x-eos-digital-rebel-xti-eos-400d-digital.pdf
or other links/ideas maybe here:
http://thydzik.com/canon-service-manual-for-eos-kiss-digital-x-eos-digital-rebel-xti-eos-400d-digital/
Testimonial: "Thank you, but that is the wrong model my friend."
Im trying to figure out the back button focus option
That is the usual button used for BF but in the menu you can assign a number of button for the BF function.
2answers
How do i connect the camera so i get live feed to my laptop. There are only USB inputs on the laptop.
You can't do this. You should attach the camera to the telescope, use the telescope focus wheels to focus after switching on Live View on the camera. You can also use the magnification 5x, 10x function.
Eos 70d 18-135 stm lens focus ring does not turn when focusing?
It may be that the focus ring is only engaged when the lens is switched to manual focus.
Jun 26, 2014 • Cameras
I try to focus and it tells me this function is not selectable in the current shooting mode
Yes there are two zones of selection on the mode dial. one is basic zone (in which you have potrait, landscape, closeup, sports, night portrait & flash off) these are fully automatic modes and the camera does every thing for you you cannot change the focus. you can zoom out and zoom in and when u see in the view finder the picture is blur. then press the shutter button halfway the camera automatically zooms in or out for the correct focal lenght. only in creative zone you can do it. like programe ae , shutter priority , aperture priority , manual exposure. Hope this solves your problem. Prashanth.
New out of the box Cannon 550 with a 18-55mm 3.5 - 5.6 lens and I can only focus in the wide angle shot. The zoom to 55mm is out of focus even when set to AF and an automatic setting. Am I doing...
In automatic mode and automatic focus - The camera should focus onto the subject given that there's enough contrast between your subject and the background. If it not focusing at all even in broad day light conditions - You lens is faulty.
Also - Do you or your friend have another lens to test if the camera is faulty?
Canon powershot sd 1000
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
