SOURCE: for lg monitor warranty
this monitor having 3 yr warranty
according to the serial no it have warranty till April 2008.
SOURCE: LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor
from power and from computer and test computer with different monitor
to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing
led on front of the monitor , and monitor turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or a broken contact, identified an internal fault and kicked in
, starting the flashing light.
If
you are in situation one, then the monitor will reset just unplugging
power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common
faults
that can occurr are a blown capacitor on power board, faulty inverter
board, faulty input board, or a fault on LCD Digital Controller board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: blinking of moniter 700e lg
I think that two capacitors in the powers supply circuitry(incise the monitor) has gone bad. Just open and you'll see them.
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
SOURCE: LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
