20 Most Recent LG Studioworks 700S 17" CRT Monitor Questions & Answers
LG 700E monitor's power LED blinking continueously, no displaySolution.............
LG Studioworks... | Answered on Aug 17, 2018
You can download it from here >> http://www.lge.com/support/software.jsp
LG Studioworks... | Answered on Sep 09, 2014
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
LG Studioworks... | Answered on Aug 20, 2014
this is my other user name .. means VISHNUswamy & LORDSHIVA same person .... for big & clear pictures just email to me sathyavijayasarathibabu@ymail.com ...........lordshiva_0.jpg
LG Studioworks... | Answered on Jul 12, 2014
Remove any speakers or magnets that you might have near the monitor as they can cause visual distortion on your monitor screen.
LG Studioworks... | Answered on Mar 05, 2014
look listen and dance not matter how you performance keep it calp and trust it
LG Studioworks... | Answered on Feb 20, 2014
A width issue specially if this is short of width on the screen can be due to many reasons:1. It can be a low +B which means the SMPS power supply has a lower output due to low Switching or a low value on the main capacitor. Check this out, measure the +B on the mains end and also the secondary side which will confirm.2. If the secondary +B is correct the fault can be with the sync circuit IC or the horizontal coil or even a fault with the deflection coil. A proper measurement of the voltage in this section is important.3. Check for weak capacitors and DRY soldering on the horizontal section , line output section.
LG Studioworks... | Answered on Oct 12, 2013
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
LG Studioworks... | Answered on Jun 28, 2013
it can be a broken monitor or a faulty video card. try replacing your video card. hope this helps
LG Studioworks... | Answered on May 03, 2013
Hi,Sir/ i have lcd monitor Hp-L1502 its on position wen i start lcd without vga cable to frount lokation is red+green+blue colours step by step fliker&i can fix new vga cable.whats sulution?
LG Studioworks... | Answered on Mar 18, 2013
LG Studioworks 700S 17" CRT Monitor Logo
248 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Studioworks LG
  • Studioworks LG
Most Popular Question
lg 700e monitors power led blinking
  • Computers & Internet
