My windows XP has no problem, I guess because it's wired. I did however get it working for a short time, didn't last for very long what I did was turned wifi on and turned cellular network mobile data off. Had the system scan for an open network. It found CenturyLink0153 SSID it connected to it worked for about 1 hour. I just tried the same process and I got a different error message in the wifi connection portion located directly under the networks name ie; CenturyLink error message report's authentication problem when any of the network's tried to connect. I stopped the Mobile network setting in the Cellular network in settings,before I started this process. That's about how much I know to try to explain it you, I am definitely not a PC Whiz Kid, as you can probably can tell by my description above. I have no idea if I made any sense or not . Thank you and Best regards, Darin Hughes
SOURCE: cannot connect to internet using HUAWEI mobile connect in HP vist
chek whther those driver supports vista?othwise try to find out vista drivers from site.....and even try manual connection through network connection...
Go to settings
Go to control panel
Go to connections
Look for internet or wireless connections
Click on create a new connection
Run connection wizard or follow the steps
