SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
SOURCE: battery change for Nixon Kink watch
You have to open your watch caseback. Undo the battery holding contact, get the battery out and memorise the writings on the battery. Buy exactly the same one and replace it in the backwards way you took it out.
SOURCE: i need to replace my
Butterfly clasps come in various sizes. this sizes are usually based on the width of the watch at that point where the clasp is supposed to be fitted. All you have to do is measure the width of the watch and this should help you determine the size which will be convenient. But usually it should be something between 18 - 20 mm size. Although when you measure it you should get more accurate results.
Hope this solution has been helpful?
SOURCE: My Nixon Rotolog Leather watch
This is called spring bar or spring pin. You can buy these on ebay. Make sure you get the right size. The distance between watch lugs is the right size. Measurement must be taken in mm.
