Computers & Internet Logo
S
Susan Bess Posted on Mar 06, 2017
Avaya Partner ACS 18D phone with a completely useless display, needing to disable the ringer, but can't navigate the feature menu because of the display Do you have a step-by-step way to achieve this?
The display is completely blank and has been for a year. This particular phone that we need to silence is in our new Family Service room, where grieving families meet to make arrangements for their deceased loved ones.
5 Related Answers
A
Anonymous
  • Posted on Dec 29, 2007
SOURCE: Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Jan 27, 2009
SOURCE: Avaya Partner ACS & 18D - Call Waiting Not Working
It's easier and more stable to program a button for FLASH (F03). The timing is in program 107 and sets to about 18-20 for 450 to 500 milliseconds.
Carl
formulacoop
  • 43 Answers
  • Posted on Mar 10, 2009
SOURCE: Which button is the 'feature button' on the Avaya Euro 18D phone?
It's the gray button labeled FEATURE just to the left of the #1 on the keypad.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Nov 20, 2009
SOURCE: partner-18D (lucent avaya phone)on the display it
Get yourself 2 alkaline AA batteries, keep the power on, and look for the door on the lower part of the face on the ACS processor module. Pop the cover and replace the batteries.
Carl
Anonymous
  • Posted on Mar 15, 2010
SOURCE: How do I Change Tine on a AVAYA PARTNER 18D Phone?
Press Feature 00 (zero, zero) from station 10 or 11. Press left intercom button twice, press #103, and then enter time in military format (24 hr). Press feature 00 again. This is all done with the handset down.
My avaya partner 18d phone does not ring how can I turn on my ringer
Hello Tom,
Avaya actually has SEVERAL "PARTNER"
models referred to as 18D... but when I was associated... they WELCOMED CUSTOMER CONTACT opportunities in the
continental U.S. ... call their toll-free Heipline,
available 24 hours a day, at 1 800 628-2888.
You should first check your owners manual...
The most likely cause:
is the "DND" (do not disturb) Feature is "ON".
If you books are not immediately available AVAYA customer support can assist your EVERY COMMUNICATIONS NEED.
For free manuals check out the URL (link) below...
If you are still stunned (a lot of buttons) comment me back with the EXTRA 3 characters in the name... and I'll look up your precise model.
Results 1 10 of 10
1helpful
Caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
How do you disable the intercom feature on an Avaya Partner 18D phone?
Unfortunately, you can not, as this would disable the ability of dialing other extensions, thus making the system useless.
You need the intercom buttons to transfer calls, so that is another reason.
2helpful
Is there an downloadable users manual? we just installed this phone and do not know how to set date/time.
Here's a link to avaya's site for a Partner ACS users guide. Not knowing which type of partner system you have, this one should get you into the ball park. Theres also programming and installation guides for the different systems there.
http://support.avaya.com/css/P8/documents/100007287
Also, here's how to change the time.
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
1helpful
I need to set the ringers to only ring at the two receptionist desks and not everyone else's offices. Please help! We have Avaya Partner 18D phones.
Partner ACS systems come with Centralized programming instructions. Most of them starting with Feature 00 Left Intercom twice and Right Intercom. When you dial an extension, the lights will be solid or blink according to how it's programmed and you press each button to turn on or off or delay ringing.
Your system administrator should have a book.
Carl
12helpful
How do i change the time on my avaya 18d series 2 partner phone
Partner ACS, any release
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
15helpful
1helpful
Partner-18D (lucent avaya phone)on the display it
Carl
2helpful
Avaya Lucent Phone Questions
Those are pretty easy requests. At extension 10 or 11 go to the phone and press FEATURE 00 LIC LIC (where lic is the left intercom button) #103 and dial your time in 4 digit military time. If you need the date its #101. Press Feature 00 to exit.
Manuals are always available for download at www.avaya.com and you have to search for them. I also have one on my public website at http://public.carl.airpost.net/Avaya/Partner_ACS.pdf
This is for an ACS 4.0 IIRC. It works for most applications.
Carl
Top Avaya Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
