SOURCE: Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
SOURCE: Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
SOURCE: neff dishwasher water not been pumped out
ck drain for kink in hose . and if connected to disposal ck the hose at that point . must be clear. ck for bone/glass / toothpick/ ect / m m
SOURCE: I have a Neff W4380 integrated washing machine
check the drive belt sir, it is.
Testimonial: "I shall try all this out tonight...have ordered some carbon brushes. Hope it works. Thanks"
SOURCE: Fill Fault appears during wash cycle.
Is the filter in the hose where it screws onto the tap clean?, if this is okay then most likely the valve.
Testimonial: "Hi, Thanks so much for the reply. I checked the filter in the hose and it appears 'clean'. As you said it may be the valve. Thank you Stephen"
