SOURCE: jvc gr-d3ou video camera
My problem (posted above) was with the CCD. When I spoke to a JVC rep in early December, the deadline at the time for free repair was early November or October, I'm not sure which. He said just send it in to the nearest factory authorized service center with a note explaining the problem and they'll take care of it free of charge. No RMA needed. And I got a free repair with fast turnaround. I suggest to others with this problem to just send the camera in with a note and they'll probably take care of it for free. If they want to charge you they'll have to ask for permission first. Being the camera is unusable as it is, what have you got to lose?
SOURCE: JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
SOURCE: PC does not recognize the video recordings of my JVC Everio GZ-MG21
Actually if you just change the .MOD endings to a .MPG it should work just try it on a file you have copied but keep the original intact. I also had the same problem with the JVC piece of junk I bought. This is what I found out on the net. It works but I don't know if there is and loss in the process
Rick
SOURCE: Can I stream live video from Firewire interface?
Veodia’s recently released streaming-video software is easy to use. Really easy. We’re talking plug-and-play easy. Plug your DV camera into your computer and put it in record mode. Log into Veodia.com and hit “new broadcast.” And you’re live. Instantly. And when you’re done, you hit stop and the video you’ve just streamed is available on demand through your favorite RSS feeder. Instantly. And it works.
When you hit “start broadcast” Veodia takes about 5 seconds while “detecting bandwidth.” The end product is a 320 x 240 live video feed streaming right out of your Firewire DV camera or webcam. This video is embeddable anywhere, meaning you can have this live feed be part of your blog and your viewers don’t need to be registered Veodia members. And each broadcast comes built in with a chatroom for your viewers to interact with you, the webstar, live.
SOURCE: Video Playback on a Everio GZ-MG57U
Sounds like you just need to upgrade your codecs. I use media player classic or VLC media player so I've never had these "not" play. Also another thing you will run into is the widescreen not showing properly when it does work. You have to convert the video to proper divx format with Xillisoft video converter in order for it to appear in 16:9 in all players. Makes the files 1/10 of the size too with little quality loss. Make sure you get the newest divx and xvid codecs, or a media player codec pack (easily found in google).
