Brother LS-2125 Mechanical Sewing Machine Logo
e
ella hedrick Posted on Jan 29, 2017
I need a walking foot for my Brother LS2125. Can you help
Stephanie Cabell
Level 1:
Problem Solver:
  • Contributor 22 Answers
  • Posted on Apr 30, 2017
Stephanie Cabell
Contributor
Level 1:
Problem Solver:
Answers
22
Questions
Helped
6857
Points
62
Http://www.sewingpartsonline.com/brother-ls2125-sewing-machine-parts.aspx?utm_source=msn&utm_medium=cpc&utm_campaign=%28roi%29+brother+-+%28sku
1 Related Answer
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Oct 05, 2012
SOURCE: What walking foot would fit a Brother LS2125 sewing machine?
check with a brother dealer about a walking foot
1helpful
Brother sewing machine LX 2500
Walking feet attach much the same way on most machines. They can be boogers the first couple of times. It helps to tilt the foot and guide it toward the needlebar from the side in order to get the fork (if your foot has a fork--some just have a bar that sets on top of the needleclamp screw) around the needleclamp screw. In cases of extreme frustration, I've removed the needleclamp screw and then reattached it once the foot is in place.
Just use patience. If frustrated, walk away. Whatever, do not force or bend the foot in order to install.
How do attach the walking foot Brother
How to use the Brother SA140 and SA188 Even Feed Walking Foot
How to Use the Brother SA107 Walking Foot
Attaching Walking Foot
How to attach walking foot to your sewing machine Elizabeth Ruffing Art...
Problems installing my walking foot
Brother cs6000i thread tension issue
Logically, the top thread should not be affected by a walking foot as the thread operates independently of the presser foot.
Suggest removing the top thread totally from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Check that your walking foot is installed correctly--the fork-shaped piece needs to encircle the needle clamp screw.
If you continue to experience problems with the walking foot but none of the other feet, recommend contacting a Brother technician.
The foot fell off and i dont know how to put it back on i have a brother model ls2125
If, you read your book you will see how to do it. And if, you do not have your manual, go to www.brother-usa.com, under support, click on home sewing and embroidery, then select your model, and just below you will see your manual to download. That is free. The reason that I couldn't answer you was because you the foot fell off, did you mean the snap on one or the snap on foot adaptor? If, the book does not work for you write back.
I don't know how to attach the walking foot to my LS 2125.
When installing the walking foot, you must make sure that the arm that moves up and down is resting on the needle clamp screw. That arm controls the movement of the foot and that allows it to do its "walking" if it is not resting on the needle clamp then it will not work at all.
Walking Foot for Brother LS-1217
Beckster, it may simply be that the walking foot needs to be tweeked a bit, perhaps screwed in further, or less.
If that doesn't help ...
Check out this site. All the Q&A answers in simple language, as well as a GREAT cust. support staff. (its a Brother after all!)
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
Brother LS-2125 presser foot stuck
i bought a new brother stiching machine ls2125. when i started to stich the same no stiching is coming only the mark is coming. why?
Pressor foot
Go to this link on the Brother website to order:
http://www.brother-usa.com/homesewing/modeldetail.aspx?PRODUCTID=LS2125&tab=optional
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
