ok, a simple hardware question only. w10 could careless about PSU. (facts) mobo is micro atx size 24.4cm x 24.4cm
not powering up has many causes, even simply stuck in sleep mode. (power on button held for 10seonds and released last is 1 cure. of about 20 causes (up to)
GA-F2A78M-D3H (rev. 3.0)or
rev. 4.0?????
rev is on bottom left of mobo, normal tower case. no case told
the PSU is called ATX and all work here 500 to 750watts
24 pin power is normal
but CPU power uses 8 pin power plug PSU.marked ATX12v
psu lacking 8 pin, can use 4 to 8 adpater.
vast here work, in real ATX case not micro cases.
https://www.newegg.com/p/pl?d=psu+atx&N=4131%20100007657%20600014006%20600479294&isdeptsrh=1&Order=1
from you manual .
dead PC
are all fans dead.> that is dead PC.
the monitor must be good and connected the the VGA jack
if using GPU card then it must connect to the monitor
the BIOS screen must work or the PC is dead or GPU card is dead.
strip the PC down ,any thing in the PC shorted will make PC dead.
if strip down tests fail the PSU may be bad is its fan dead too?
both power connectors most be connected above or PC will be dead.
